How to remove driver's side visor on 2005 S40?
I have had the dreaded sunroof blocked drain again on my S40 which I have cleared and the tube runs clear. However, in the process the connection from the drain hole in the roof to the internal tubing has come loose and I need to remove the ceiling trim to get access to reconnect it. Attached to the tubing that runs down the A pillar is a black plastic elbow fitting and another section of plastic tubing that must connect directly to the sunroof drain hole.
I have removed the handle in the ceiling at the drivers door, and I can see that there is one visible screw at the left of the visor but on the right hand side, where the swivel arm is attached, there seems to be a plastic cover over where another two screws are. I am reluctant to just force this cover off to prevent any cosmetic damage. I am looking for a pointer on how to remove this little cover so that I can remove the visor to gain access to reconnect the drain hose. Long story short!!!
Thanks for any assistance.
I had gathered that but I wasn't sure exactly how to do it to minimise damage. I can see that it moves freely and must clip off somehow but I was reluctant to use great force. I did find this:
Write up: S40 (MY2005) Headliner Removal and Repair
Thanks for your reply.
Sunroof Leaks - Part 2
OK - what part of a sunroof leak would dump water on ONLY the drivers side REAR carpet? Is there a particular drain tube which can be accessed from somewhere that would cause this? Front carpets are totally dry, so I am guessing the typical front pillar drain tubes are working correctly. Are there some rear tubes?
shoeboxOH
11-11-2013 05:50 PM
