leaking oil pan again
Old 02-27-2017, 02:57 PM
Newport_j's Avatar
Default leaking oil pan again
The oil pan on my 2002 Volvo s40 automobile is leaking. I do not know how to fix it.
I take it into a garage and no mechanic will touch it because the oil is leaking.
The oil pan has already been drilled and a new larger plug has been added. I really do not want to buy a new oil pan; is there any alternative?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old 02-27-2017, 03:41 PM
ES6T's Avatar
If its leaking from the plug and it has already been modified, replace the pan.
Old 02-27-2017, 04:00 PM
AutoNaut's Avatar
Is it coming from the plug or could it be from the turbo oil return line?
You may be able to get a used pan or one off ebay. They don't look too hard to replace.
Old 02-28-2017, 04:03 AM
Hudini's Avatar
I too would question the source of the oil leak. Where exactly is it leaking? The plug, a crack, the oil return line, the gasket? You can use fluorescent dye and a black light to pinpoint the source of the leak.
Old 03-23-2017, 08:05 AM
Newport_j's Avatar
Okay, I believe that I must replace the oil pan. It is too risky to drive around with a leaky oil pan.
I will try and get one used, but I need to know how big a job is this?
It does to require more than just a replacement oil pan. Say gaskets are required to
seal the pan once a replacement has been found and installed. Is there a gasket kit available?
Respectfully,
Newport_j
Also, someone said that secondary oil pan is required. What are they talking about.
On a 2002 Volvo s40 once the oil pan is removed there is a secondary pan that must also be removed. What is this about and what is the secondary oil pan's part number?
I think that there is no doubt the oil pan must be replaced, I am just getting prepared for the job and I need some direction.
Old 03-23-2017, 11:02 PM
ChemDad's Avatar
Here's a diagram of the lubricating system, hope this helps
Lubricating system. Fits: 2002 Volvo S40 2.0l 4 cylinder Turbo | Smith Volvo
Old 07-05-2017, 08:00 AM
Newport_j's Avatar
I got an oil pan for my 2002 s40 Volvo from Amazon for about $ 170.00. It did not fit, in spite of what the fitment software that Amazon uses for checking whether a part fits your car said.
I should have known. There is no way you can get a 2002 Volvo s40 oil pan and gaskets for that price.
I am asking now where can I get a reasonably priced oil pan for this car. Also, I need the gaskets and the all other accessories.
Respectfully,
Newport_j
Old 07-22-2017, 09:42 AM
Corey Conklin's Avatar
For those who have responded... at which point would a leak originate that would leak directly onto the exhaust? This is my current issue.
Old 07-22-2017, 04:22 PM
check the turbo oil return line seal - you may need to remove the heat shield to get a look see (at least on my 850 that's what I do)
Newport_j
03-26-2015 09:25 AM
ludeless
08-13-2014 01:53 PM
ibified
10-12-2010 08:59 PM
mercb
12-11-2009 01:49 PM
Keith Tobberman
11-26-2007 12:35 PM
Quick Reply: leaking oil pan again
