Low beams still not working
Hi guys,
I was thrilled at first when I found this post:
https://volvoforums.com/forum/volvo-...working-37696/
....but after I bought the relays then took my dash apart low and behold those relays are working fine and I have power from the switch to the CEM and to the fuse box but not the low beams??? Does anyone have the wiring diagram so I can follow from the fuseBox? My high beams are fine and I bought new bulbs just because. anyone have any idea what to check next???
thanks
thanks
Traced things a bit further
OK, so I traced the wires all the way to the headlight assembly/ Housing and I have power at the harness that plugs into the assembly. Thats all I can do without taking the assembly out. I attached an image I got off EBay of the same light housing as I have(so you can see what I was talking about) , what is the blue plug for and why do I have power to it on both driver and passenger sides but no low beams???
Thank you
