Major front end noise
  #21
Old 03-13-2006, 06:50 PM
Default RE: Major front end noise
Yup. In Tennessee we have a game that we playwith some of roads down here--The guy or gal that gets to work without hitting a pothole wins a prize. Our State flower is an orange road repair barrel. Lol. BJ
  #22
Old 03-13-2006, 09:49 PM
I TOLD YOU SO I TOLD YOU SO!!!!!!!!!
LOL
  #23
Old 03-14-2006, 12:57 AM
gordon368's Avatar
now now, that doesnt give u bragging rights..
  #24
Old 03-14-2006, 01:03 AM
ORIGINAL: gordon368
The Jurry is still out on that one!!!
  #25
Old 03-14-2006, 01:34 PM
Excuse me. Does the Moderator of this bodacious site get to say "I told you so?" I call foul on that.BJ
  #26
Old 03-14-2006, 07:31 PM
Agree to TECH.Check the sway bar or known as stabililzers.There should be 2 clips/clamps which holds the bar in center position.Could be the clips/clamps on the passenger side crack or broken which in turn unable to hold the sway bar.So when u hit on rough road the bar moves and could be hitting the structures around it as it is very close,causing the noise.Or try to steer full left and right in stationary position you might hear some noise.Look carefully on the condition of the clips.
Cos it happened to my car.The sway bar clips/clamps on the passenger side had obvious crack.Got it replaced, after sometime seems like the clips/clamps unable to hold the bar in position.I can hear light noises now when i steer the car.
OMG another problem for me.
Vollic
  #27
Old 03-14-2006, 09:50 PM
ORIGINAL: hocbj23
LOL
  #28
Old 03-15-2006, 06:03 AM
I had a problem similar to this, it turned out to be the driver shaft.
  #29
Old 03-15-2006, 11:39 AM
ZIGZAG's Avatar
I think it is sway bar bushing, I am going to get them replaced hopefully this weekend. You cant see them without taking some stuff apart. I hope this is the problem. the vertical tile to the wheel is loose and moves a bit. I was only going to do the one but I think I might just do both and then should not have problem later.
  #30
Old 03-15-2006, 08:42 PM
ORIGINAL: ZIGZAG
Yes do both. The sway bar has to come off to get to them anyway.
They are a pain in the A** to replace. The front Subframe has to be dropped to get to them.
  #31
Old 03-17-2006, 01:56 PM
ZIGZAG's Avatar
are you kidding, i think my guy is going to be in over his head then, nobody here knows who much to charge for it.
  #32
Old 03-17-2006, 09:34 PM
ORIGINAL: ZIGZAG
No im not kidding. If you look under the car. The bar that runs from front to back will have to come off.(The one with the engine mounts. The where the lower control arm bolts look up you will see screws from the subframe to the body. They have to come loose but not out. The steering rack needs to be removed from the subframe and left hanging and supported. Then the sway bar can be gotten to.
Wing0
12-13-2013 02:39 PM
tomecsi
10-25-2011 12:17 PM
casbourne123
05-09-2008 09:13 AM
Sweet T5R
06-04-2007 06:28 PM
ENDEE666
12-06-2006 03:44 AM
Quick Reply: Major front end noise
