No start condition - Need ideas
I was driving my car home (2004.5) a couple of weeks ago and came to a red light. As I started slowing down the car died. Now it won't start. All I'm getting is a single click from the starter and then the lights dim if I keep the key turned. As soon as I let off, everything is back to normal brightness. Everything else works as normal.
Here's what I have done so far:
-Changed starters (had an extra one laying around)
-Tried starting the car with a known good battery
-Inspected battery cables
-Turned the engine by hand to make sure it's not seized (it's not)
-Pulled starter relay, nothing happens with it removed but clicks when inserted
I'm out of ideas...am I missing something? I haven't checked the alternator, but I would assume the car would crank even if the alternator was bad.
the solenoid click sure makes it sound like either a bad cable (or connection) from the battery to the starter, a weak battery or bad starter... I agree that with an immobilizer, PNP or ignition switch problem you wouldn't expect a click... Regarding the alternator, it is conceivable that a bad voltage regulator could be draining the battery... I presume your lights and accessories work?
Update.....checked the voltage drop from the battery to the starter while trying to crank. Voltage at battery is 12.71 and drops almost 3.5 volts by the time it gets to the starter...ugh. So even though the cable looks ok, I think I've found the culprit. I'll replace the cable sometime this week and hopefully this will take care of the no start issue.
This should also explain why the car died suddenly as the alternator is not able to charge the battery through a bad cable and the car was running of the battery until it finally discharged.
Volvo wants a ridiculous amount for new cables, so I'll be making my own. I'll report back with results.
The reason the fuse popped is because the cable wore through in one spot and shorted out against the starter.
Jadeline
07-14-2015 12:08 AM
dawgduo
07-27-2011 08:20 AM
pcr5946
11-17-2010 04:41 PM
