P0722 - Throttle Position Sensor
Old 01-14-2017, 01:52 PM
Petergdodd's Avatar
Default P0722 - Throttle Position Sensor
Hello everyone. I am new to this site and looking for a little advise:
I have a 2002 S40 1.9T Automatic with 158,000 miles. It runs like a champ, but recently it has displayed the Check Engine Light. Reading the code shows P0722 (Throttle Position Sensor). I have cleared the code two or three times, but it comes back after a number of journeys. Transmission shifting appears to be normal.
This leads me to a couple of questions:
1. Has anyone had this fault code and, if so, what was the cure?
2. My trusty Haynes manual shows two transmission control sensors: vehicle speed and transmission speed. Is P0722 caused by one of these? If so, which one?
Thanks in advance for any help!
Pete.
Old 01-16-2017, 04:05 PM
could be a ground wire issue on the transmission or the transmission (output shaft) speed sensor - Google Volvo PN#30618272 Its about $100 so no too bad...
Old 01-17-2017, 05:47 PM
Petergdodd's Avatar
Thanks for the feedback. I will certainly take a closer look at the transmission electrical system. Is there a way to check the sensor (e.g. continuity) or does it fail in different ways so the only sure method is replacement?
jdmser
08-29-2019 05:29 PM
rodneygt
09-01-2016 08:51 AM
2001v70xc
10-24-2011 08:34 PM
sparkjr
06-13-2010 08:28 PM
DENNISVHANK
10-22-2005 02:49 PM
Quick Reply: P0722 - Throttle Position Sensor
