Help! Car suddenly shakes
Old 12-22-2006, 02:30 PM
jonnycd's Avatar
Default Help! Car suddenly shakes
Yesterday, my 2000 s40 developed a pronounced shake, and a clacking sound that speeds up with speed. At a slow speed it feels almost like a bent rim, but then around 60 mph its a quick shimmy. It sounds like its on the driver side. It started yesterday, then it disappeared for awhile at high speed (70+) and it didn't do it today until midway through my commute. I revved it in nuetral and the engine is running smooth, so its probably something in the driveline. It seemed almost like the wheel lugs were loose. I'll check that, but its probably not that. Any ideas???????????
Old 12-22-2006, 07:13 PM
Default RE: Help! Car suddenly shakes
Maybe bad Axle.
I have also seen the Transmissions break as well and cause the same thing.
Old 12-22-2006, 08:48 PM
could be a balance issue with ur tires, when was the last time u had them rotated or changed?
Old 12-26-2006, 09:39 AM
I had the same problem. Dealer had to replace the front axle.
jesseb
12-12-2011 12:26 PM
AnEskimo
05-15-2011 12:29 PM
CyDetrakD
02-22-2011 05:08 AM
ibpitty
05-11-2009 09:36 PM
morrobaybum
04-06-2009 06:43 PM
Quick Reply: Help! Car suddenly shakes
