rumbling noise
Old 01-14-2006, 11:55 AM
templar's Avatar
Default rumbling noise
I have a '99 S40 1.8 5 speed manual, 76K which has developed a rumbling noise which gradually becomes more of a whining noise at higher speeds. It sounds exactly like a wheel bearing but having jacked the car up and driven the front wheels the bearings are quiet. The mechanic (not a volvo specialist) thinks the noise is in the gearbox but I disagree as the noise is constant (doesn't change pitch when I change gear or coast in neutral).
Any help would be much appreciated.
Old 01-14-2006, 12:24 PM
Default RE: rumbling noise
I would look at the tires. You may have one out of round.
Old 01-15-2006, 10:45 AM
templar's Avatar
Thanks tech. All the signs are pointing towards the tyres. I'm taking the car to my local tyre place tomorrow
Old 01-15-2006, 10:47 AM
Let us know how it goes.
Old 01-17-2006, 05:41 PM
templar's Avatar
Both rear tyres pentagon shaped on inside edge! Noise now 70% eliminated - suspect will have to change fronts soon too. Any idea what would cause the tyres to get so out of shape on one edge? I've seen this many times on front tyres when the tracking has been out, but not on rear tyres.
Old 01-17-2006, 09:44 PM
There is alignment adjustments for the rear as well.
Also it could be the tires. A belt might have broke.
duikboot
11-04-2011 01:18 PM
rspi
01-20-2010 11:32 PM
1998xc70
10-29-2009 02:02 PM
TarHeel79
01-16-2009 01:57 PM
rationull
09-16-2007 12:32 PM
Quick Reply: rumbling noise
