s40 1.9t automatic transmission problem
on
1 Post
An urgent drain and fill procedure on the transmission would be good starting point especially if very dirty and has sat for that long unused.
Assuming its a 5 speed use only a JWS. 3309 spec'd fluid only.
The Dex III or IV is okay for a 4 speed.
You will need to repeat the drain/fill process about 3 times to get the fluid looking a new clean red colour.
Do approx' 100 miles or so between each fill.
lost part in accident
I have lost the outside sensor/control that is near the water bottle at the front bumper, I believe this is the part that will re-activate my heater and ac controls at the dash is this right I hope. I am curious what that is called there are a lot of wires to this Sensor/control. Thanks sea91406 https://volvoforums.com/forum/images...s/confused.gif
sbuckner
10-16-2012 09:54 AM
