s40 2011
The button on shifter on mine sticks
makes sure its all The way out.
Had to wd40 the plastic
stuck in the ignition switch or stuck in the ignition on position??
Assume you mean stuck in the switch - so 1) make sure the steering wheel is not cranked to the side (putting pressure on the steering lock) 2) unlock the shifter (key on position, brake on, if needed use/pop out the unlock button.) 3) try the shifter row (top to bottom 20X) to clean the PNP sensor contacts.
volvie!
West
02-24-2011 04:53 PM
