S40 Blower Motor Resitor replacement - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 01-07-2009, 10:03 AM
Default S40 Blower Motor Resitor replacement
I have Volvo S40, 2003. The blower in this is stuck at hight speed. I was told that it need to replace the "Blower Motor Resistor"
Where is this resistor located, how can Iaccess it ?
Old 01-09-2009, 03:04 PM
Default RE: S40 Blower Motor Resitor replacement
Any help ???
Old 01-09-2009, 03:47 PM
I thought someone was going to reply with the link like usual but they didn't.
There is a little black resistor under the dash. Remove the glovebox there is screws around when you open the glovebox.
Then remove the lower carpeted panel it is only a couple of clips.
The look along the metal bar that runs along the bottom of where the glovebox screws to. Just to the right of the center there is the black resistor. If I remember correctly you will need to loose the dash on the right side to get the resistor out.
Old 01-10-2009, 12:33 PM
Lyonsroar's Avatar
There is a how-to on s40concepts.net/forum as well!
Thread Thread Starter Forum Replies Last Post
2005 S40 Heater/AC Blower Motor Replacement JohnnyRocker Volvo S40 1 07-25-2014 02:34 PM
Blower motor replacement? yert315 Volvo 850 32 03-17-2013 08:59 PM
E.C.C resitor bypass? scott_boston Volvo 850 7 08-28-2011 02:17 PM
2001 S60 Blower Motor Replacement hohoho43 Volvo S60 & V60 0 03-20-2008 12:00 PM
Blower motor replacement RPMCanes Volvo S70 13 01-02-2008 03:45 PM
Tags
2000, 2003, blower, change, fan, location, motor, replace, replacement, resistor, resistro, s40, transister, transistor, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
