S40 engine trouble
Old 11-29-2014, 11:17 PM
mwbridgwater's Avatar
Default S40 engine trouble
Hi everyone... registered here today to get some repair advice. I have a 2005 S40 2.4L (186,800 miles) that has had problems at times with lack of power when driving and not starting/idling properly. Got an OBD II reader which initially gave me six codes before clearing and trying again:
P0089 Fuel Pressure Reg 1 Performance
P0171 System Too Lean (Bank 1)
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor CKT Range/Perf
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0455 EVAP Emission Control System Leak (Large)
(The above definitions came from the Actron book with my reader.)
I cleared it, drove the car around the block once and checked again. Just three of the same codes came up this time; P0089, P0171, and P0190.
I don't have a lot of maintenance experience with this car (Or any Volvo) since I got it just a year ago. So far, I've just replaced one engine mount and removed shims from the A/C compressor clutch to get that working again.
Any information on how I should proceed with what ails it now would be greatly appreciated... the what and where of it.
Thanks,
Mark
Old 11-30-2014, 01:18 AM
damien360's Avatar
Sounds like the fuel pressure regulator has gone bad. Common problem on p1 s40s
Old 11-30-2014, 12:22 PM
Hudini's Avatar
Fuel Pressure Sensor. The newer 2004.5 + Volvos don't have the traditional Fuel Pressure Regulator like the 2000-2004 1.9L models. The newer models use variable voltage supplied to the fuel pump to change pressure.
The gray thing on the fuel rail in front of the oil fill cap.
Old 11-30-2014, 02:12 PM
Thanks guys, I'll check those out.
Mark
williem
04-21-2015 09:52 AM
elcs70
06-25-2009 07:28 PM
jdsr917
02-22-2009 01:11 PM
simeyrocks
01-30-2008 07:58 AM
whwood3
10-20-2005 09:12 PM
Quick Reply: S40 engine trouble
