S40 Turbo Issues
S40 Turbo Issues
Hey guys,
Haven't been here in a long time. I'm in the medical field now and that world tends to suck you in. I haven't been under a car hood a more than a year! My hands don't have that lovely grease-monkey look they used to have[&o]
On to the problem:
I'm still driving a 2001 S40 1.9T now with 84,000 miles. She has been giving loads and loads of problems as of late. I just had to spend 2400 dollars to get a few issues fixed after my powersteering failed during winter driving.
The most recent problem has me considering going back to a Toyota/Honda setup because this is just not sounding bad.
I may have lost a lot of my gearhead instinct and it's pointing towards a blown bearing so tell me what you think.
When the car is in Drive, during acceleration I hear a whistling tone which increases in loudness as I work my way up the RPMs. It is actually occurring during turbo spool from what I can tell.
It is doing the same problem when in Neutral. It does not have any mechanical tones to it it (grind/crush/etc) It does NOT sound like a belt.
Oddly enough, I don't have smoke of any color coming out of the exhaust, which would normally be associated with a turbo failure.
Anyone have any thoughts?
On to the problem:
RE: S40 Turbo Issues
It could simply be the intake to the turbo is loose and sucking in air after the air filter. I have a project car that I installed a turbo and have a short intake with the air filter located in the wheel well. When the turbo spools it sounds like a jet engine spooling up. I can easily see our cars doing the same thing with a loose hose. It may even be between the turbo outlet and the throttle body. Just a guess.
ORIGINAL: Vender
Thanks for all the help guys.
I dropped the car off at Volvo after I found no evidence of a loose intake etc. Just got the call from them, the turbo is toast
Not sure what the most cost-effective way of getting it back on it's feet would be.
Maybe try to find a used one.
BTW nice to see you back even if it is for an hour or so LOL!!!
Hannahlyn13
06-03-2011 12:23 PM
