Safe to drive with P0128 code ?
I have a check engine light and have read the code as P0128. I have ordered the parts for repair, but they won't be here for a few days. In the meantime, my wife needs to drive to Buffalo on Wednesday, which is about 400 miles round trip.
Would it be safe to drive this far before getting it fixed, or should we just rent a car for the day ?
Thanks for any input !
Hahaha. As of now, it running normally...
Had the same problem and drove for three weeks. Problem was a leaky thermostat gasket. Just make sure to change your oil right after you fix the problem. If you do not get the engine hot enough, which can happen with short trips with this code, you can develop emulsions in crankcase. Check inside dip stick tube and look for any milky buildup.
I just replaced the t-stat and ECT sensor. Easy job. Less than 1 hour, with the right tools.
Now I need to add a little coolant. The manual says use Volvo coolant only and not to mix them. I have a gallon of BMW coolant in the basement...
Can I top it off with any coolant or should I wait and get the Volvo coolant ?
Thanks
Thanks
My 2000 S40 only has 48000 miles on it and the coolant has never been changed... Volvo says its a lifetime coolant... Probably should change it, though, yes ?
Also, is there a shelf life for an open container of coolant? I have a partial gallon of coolant that is probably two years old...
