Sensor identification 2005 S40 2.4 non turbo
Old 11-30-2014, 05:07 AM
cljimmy72's Avatar
Default Sensor identification 2005 S40 2.4 non turbo
Sensor identification 2005 S40 2.4 non turbo-img_1720.jpgWhat sensor is located in the exhaust manifold?
Old 11-30-2014, 08:03 AM
ES6T's Avatar
That would be your front oxygen sensor.
Old 11-30-2014, 08:44 AM
cljimmy72's Avatar
I purchased two O2 sensors. One downstream which fit by the catalytic converter (Denso 234-4450). One upstream which I hoped would fit at the exhaust manifold (Denso 234-4734). It would not mate up connecter wise. Rock Auto shows another (Denso 234-9150) upstream sensor with correct connector alignment tabs. Would this be the correct sensor. Very confusing looking at parts suppliers as to what I need. Why all the options?
Old 12-10-2014, 04:39 PM
cljimmy72's Avatar
Just to let anyone know that runs into the same problem-Yes the Denso 234-9150 is the correct sensor. It is an air-fuel ratio sensor.
Old 12-14-2014, 08:26 AM
cljimmy72's Avatar
This will be the one and only Volvo we will ever own. We bought this car brand new and have had nothing but problems with this car. Top of motor rebuilt at 40000 by Volvo because it was consuming oil (sixty thousand miles later eating oil-not leaking-same as before). Two power steering pumps, two fuel pumps, ignition switch, trunk release, alternator, battery discharging overnight, and the normal maintenance things like front and rear hubs. All we were trying to save in gas went to repairs and then some.
Old 12-15-2014, 04:24 AM
Hudini's Avatar
Ouch, sometimes you get a lemon. Maybe a lease vehicle would be better?
cartesianlogic
11-22-2014 07:44 AM
Ablorx
07-04-2014 08:33 PM
2001S40nj
11-20-2013 12:52 PM
ivanprki
08-23-2011 08:45 PM
jessica
04-28-2010 11:11 PM
Quick Reply: Sensor identification 2005 S40 2.4 non turbo
