Srs air bag service ?
Hello im new to this forum done oil change and filter on 2012 s40 1.6 drivE on Saturday and replaced air filter after lowering car off the ramp and starting it the srs airbag service URGENT lights were on and message appeared wasn't on before and has remained on since car was worked on by me and my mate and treated well plugged in to two different coed readers but no codes coming up on either but lights and message appear every time you start the car have disconnected and reconnected battery for one hour but still remains
any help would be gratefully recived
thanks dale
thanks dale
If you do ANY DIY work at all, a clone DiCE/ VIDA tool is an excellent investment. The "srs airbag service URGENT" message pops up if there is ANY deviation from stock configuration. That could mean merely a mis-fastened plug or something deeper. DiCE/ VIDA will tell you exactly what to fix.
I had the same message that couldn't be cleared. Buying a $100 DiCE / VIDA saved me from spending $1700 to do the repair the way the dealer wanted to do it.
The full Volvo fault codes are pretty specific, however! In my case, VIDA said that the cause for the "Urgent" message was that a LED had blown in the DIM. I dug in, and in fact there was a hole where the LED should have been. (It was the warning LED for the SRS system.)
You can read all about my adventures at:
2006 V50 Back from the Dead
