Turbo or not?
Old May 18, 2013 | 09:45 AM
Bluevolvos40's Avatar
Default Turbo or not?
Ok I know some volvos like the S40 cam with and with out a turbo, whats the best way to determine if the Volvo I have does or does not have a turbo? I don't hear the usual turbo sounds that most turbo cars make, but doesn't mean one isnt there...I know what to look for as far as a turbo looks like but wouldn't know where its located in the engine bay of the car
Thanks for the help you all provide!!
Old May 18, 2013 | 10:35 AM
Hudini's Avatar
All 2000-2004 S40's in the USA came with the 1.9L turbo engines. Look at the badging on the rear for 1.9 T. The turbo is located on the rear of the engine below the heat shield.
For the 2004.5 and newer models in the US you look for T5 on the rear. The engine size is 2.5L for the turbo models. Again, the turbo is located on the back side of the engine.
Old May 18, 2013 | 11:43 AM
Ours just says S40 nothing else on it unless I'm looking at the wrong place
Old May 18, 2013 | 12:20 PM
snagbranch's Avatar
decode your VIN number.
Vehicle Identification Numbers (VIN codes)/Volvo/VIN Codes - Wikibooks, open books for an open world
Old May 18, 2013 | 01:16 PM
ES6T's Avatar
Look under the hood. The turbo has a fresh air pipe going to it.
Old May 19, 2013 | 11:01 PM
john3-16's Avatar
While driving on a safe road press gas pedal to the bottom. If at 3000 rpm you notice a sudden gain of power then you have a turbo.
Old May 20, 2013 | 02:04 PM
Ok I'll do that at the track then, not about to do that on the open motor ways!
Old May 20, 2013 | 03:30 PM
You can tell on the freeway. When you go to pass a car floor it. If you pick up speed pretty good you have a turbo, if you look to the floor to make sure your foot is on the gas because nothing really happened, you DONT have a turbo. Lol
ES6T's Avatar
Or just look or check your VIN... That takes no time
Old May 22, 2013 | 06:38 AM
Hudini's Avatar
Agreed, check the VIN. Are you familiar with the VIN?
Also, what year is your car? Which country are you located?
Old May 24, 2013 | 11:49 AM
2002 I believe, yes I'm familiar with the VIN however my not so good eyes have a hard time with vins, I'm in the USA
Old May 24, 2013 | 05:32 PM
ES6T's Avatar
All 2000-2004.5 S40s in the US are turbocharged.
Old Jul 26, 2013 | 04:07 PM
ok cool, I found the inter cooler which gave it away after searching more under the bonnet.
rspi
May 15, 2014 07:36 AM
MrSplean
Jan 6, 2011 08:34 PM
1Gray760T
Nov 13, 2009 08:19 PM
katrina
Aug 31, 2005 09:25 PM
vaughn3d
Sep 17, 2004 01:32 PM
