TVC change - possable PCV....any sticky?
Old 11-20-2014, 04:20 PM
Chris Nanfeldt's Avatar
Default TVC change - possable PCV....any sticky?
2005 s40 T5
175k
recents:
FPS
CPS
Battery
timing belt
water pump
pulley
idler
tires,brakes,rotors...
I had CEL for EVap leak bank 1 too lean,
Visually inspected all hoses and seems ok.
Have recently heard whine/whistle that leads me to PCV...but intermittent
No smoke from dipstick tube. Start stall a few times. Ambient temp is 25F. garaged doesn't seem to make any diff.
TCV looks easy enough. Hose clamp and large wrench...
Any ideas fellas? thank you in advance
Old 11-21-2014, 09:57 AM
mf70's Avatar
Get DiCE / VIDA's opinion before you start changing random bits.
Old 11-22-2014, 08:13 AM
Hudini's Avatar
Does it make any difference in sound if you pull the dipstick out a little bit?
mayday_v
08-24-2008 08:57 PM
MoodsR4Cattle
08-13-2008 10:49 AM
chelmer
10-15-2007 11:14 PM
s80t6schcik
03-08-2007 09:03 PM
GeoffC
02-13-2006 11:33 PM
Quick Reply: TVC change - possable PCV....any sticky?
