Volvo S40 (2000) Front Caliper Question..
Old 09-25-2010, 05:03 PM
BigGreenGragon's Avatar
Unhappy Volvo S40 (2000) Front Caliper Question..
Hi,
I recently tried to replace my front brake discs and pads on my Volvo S40 1.6 SX (year 2000) but noticed the two bolts / pins which hold the calipers onto the brake discs were heavily rusted. I have decided not to continue with the replacement work until I can purchase four new bolts / pins. I suspect the bolt heads will disintergrate when I take them out.
The bolts appear to be long and thin and look like they go all the way through the inside of the caliper. The bolts' heads point towards the engine and not towards the roadside. One is located at the top of the caliper and the other is located at the bottom.
My question is:
Any idea where I can get replacement bolts / pins from? I contacted my local Volvo dealer (Mills Newcastle) and they weren't very helpful. They said the replacement brake pads should have com with new bolts. However, the bolts which come with the brake pads (Textar) are much thicker and shorter than the bolts holding the caliper in place.
The guy in the part's dept seemed more interested in telling my how I shouldn't have bought none volvo parts (Pagid discs and Textra pads) than trying to help me.
Any help is much appreciated.
Old 09-25-2010, 07:28 PM
I will try to get you the part numbers when I get a chance.
Old 09-25-2010, 09:30 PM
What market are you in?
In the U.S. they use regular looking screws from the caliper to the bracket.
But here are the part numbers I have.
Caliper to caliper bracket
3530866
Caliper bracket to hub
30811990
Old 09-26-2010, 03:21 PM
Hi,
I live in the UK.
Thanks
s60ag
06-04-2010 07:21 AM
holobox
10-15-2009 07:03 PM
Clash1977
04-13-2009 03:17 PM
Kaspir
03-23-2008 12:01 PM
silverado102002
06-19-2007 09:11 AM
Quick Reply: Volvo S40 (2000) Front Caliper Question..
