water coming out of heater duct under driver seat?
My check engine lights been on for two weeks and belt noise or nearby has a high pitch screaming noise that hesitates when taking off from a stop. Now water is coming out of heater duct that is under driver seat when using floor vent ! I wish all these problems were related but doubt it.
could be one of two things - If you are losing coolant, you probably need to replace the heater core and/or the o-rings. If its just water and you are using the AC, it could be the condensation drain lines are clogged. Either way you need to pull away the carpet and remove the sides to the center console to access.
