Where is 2001 S40 throttle body located?
Old 03-07-2006, 12:01 AM
harstonsharley's Avatar
Default Where is 2001 S40 throttle body located?
what does the throttle body look like on a 2001 S40 1.9T, where is it located within the engine compartment and can I clean it myself somewhat easily.
thank you very much for your help
brian
Old 03-07-2006, 01:09 AM
Default RE: Where is 2001 S40 throttle body located?
Follow the Big hose to the engine. You will have to remove the Black cover in the middle front of the engine.
One screw is a phillips and the other is a T-30. Then you should be able to access it easy.
You can clean it easily. I wouls suggest removing it and cleaning it. If you do make sure you buy a new gasket first.
Some would clean it on the car.
MFHull
10-09-2014 09:01 AM
treestone27
04-29-2014 07:40 AM
treywils66
2001-2013 model year V70
07-24-2013 02:17 PM
jtmeiners
06-29-2011 02:58 PM
shoter_hellas
04-10-2011 09:17 PM
Quick Reply: Where is 2001 S40 throttle body located?
