Windshield washer fluid doesn't spray
Hey folks, newbie here with a quick question: Suddenly, my windshield washer nozzle doesn't spray any fluid, no matter how many times I hold down the lever. The wipers move as directed, but no fluid sprays out. Any ideas what the problem could be?
By the way, I own a 2006 s40 T5. (Not sure if that matters.) Any help would be greatly appreciated!
RE: Windshield washer fluid doesn't spray
False alarm: I forgot to fill the washer fluid reservoir ... bahaha, just joking. But I wish I had been that absentminded, then this fix would be quite easy.
Actually, turns out mcguij1 is right. There's a tiny plastic cap (about the size of a button) for the joint that connects the main hose from the reservoir to the hose that leads to the first nozzle and it popped out. So whenever I pulled the lever, the fluid would give my engine a nice washing but wouldn't reach the first or second nozzle. Any idea where I can purchase this little cap? Or where I can buy the whole joint or replace the whole hose line?
$2.50 fix
I'm happy to report that my windshield washer fluid now sprays successfully. I asked a coworker where I should buy a new stock hose and where I could get a new joint. Being an ex-mechanic, he looked at it and said that all I needed to do was go to a local parts store and buy a new generic vacuum T (which is the proper name to what I referred to as "the joint").
I did exactly that and even though the vacuum T isn't exactly the same, it fit the hoses and now everything's working as it should.
Thanks so much for everyone's input! It lead me on the right path.
My cap fell out too
Hi, first post and all so go easy with me...
I have a 2005 54plate S40 and this has developed the problem of the loose washer pump hose. I can reach the hose through the gap between the driver's door and front wing but I can't see where to reconnect it. Can anyone tell me how to gain access to the pump to fit the hose?
Thanks.
Thanks.
Same problem, easy fix
I bought a replacement part at a Napa store. Didn't get to see a package but the invoice says:
Part Number: 9884
Line: NBH
Description: TEE CONNECTOR
Price: $6.26
Seems a little pricey but I'm sure it save me a lot compared to putting a mechanic on such an easy fix. As stated before, it's not exactly the same part since there's no cap. Both hoses and the sprayer port fit very snug. Honestly seems like an upgrade unless I'm missing some design point like: in freezing temps cap expands/breaks instead of hose? Anyway I run only 0C or better fluid so I'll risk it.
Thanks everyone for the advice. Old thread but just what I needed for my 2005 S40.
Part Number: 9884
Line: NBH
Price: $6.26
windshield sprayer does not work
HI, 2001 Volvo s40. Sprayer doesn't work. When I pull lever, windshield wipers go, no fluid comes out. Reservoir is full. So if there was leak in hose, reservoir would be emptying out, which it doesn't. I am in Chicago, very cold winter. Thinking either need a new washer sprayer pump/motor, or is it possible something is frozen blocking the fluid? Trouble with latter is I would think from the engine heating up and today, it is finally in the 20's that it would unfreeze. Anybody have thoughts, and how difficult is it to replace the motor? Where can I get one. Thanks.
Just wanted to chime in and say thanks for everyone's help here. I needed to replace my 2009 S40's T-Valve because the cap had popped off (see below) but had no idea what it was called. I went to my local parts store but they didn't have one. Found one online at Voluparts for $6.25 plus shipping. Replaced it and everything is working perfectly!
#17
My local garage managed to fix my problem - it seems the hose had become trapped and the pressure was blowing the pipe off the reservoir.
My current problem is that my headlight washers don't work. The reservoir is full and I have had the fuse checked. Is there anything else I should check?
#18
Assuming that your S40 has the same system as my V50, you can get access to the back of the highpressure pump by removing the driver's side wheel liner. You will see the primary pump, and you can do basic troubleshooting from there.
Assuming that the Headlight washer pump is putting out water, you can check that the fluid can get to the headlight nozzel area by G E N T L Y pulling the nozzle out and disengaging it. You can see what should be happening at:
Volvo Headlight Washer - YouTube
#19
Would anyone happen to know where the windshield washer pump fuse is located on a 2005 Volvo T5 awd.....checked under the hood and under glove box inside and nothing marked as such.....would it be marked something else??.....pulling lever and no spray and no sound
#20
The fuse list is on page 180 in my manual. You can get PDF copy if yours is missing.
