'01 Trans Flush Tutorial?
Old May 1, 2007 | 09:54 PM
cesupro's Avatar
Default '01 Trans Flush Tutorial?
I've read around here a bit, and searched a bit,... and saw a lot of talking about the fluid, and the reasons to do it yourself opposed to paying $400 dollars for it. But, I can't find a simple 'tutorial' as to how to do this. Is there a good site that you guys looked at to see how to do it?
I think this is what I need to do. I have a 2001 s60 t5 with about 86k on it, and i'm not sure if the trans fluid has ever been changed. Recently (and more frequently) the car has been not shifting regularly, and it will just rev up without actually engaging. So, it sounds like the similar symptoms that you guys mentioned. Let me know if you think doing the D & F will remedy this issue. Also, if you can point me to a good link with a step by step tutorial. that would be great.
Old May 2, 2007 | 03:30 PM
billofdurham's Avatar
Default RE: '01 Trans Flush Tutorial?
This is the VADIS instructions for changing the transmission fluid. The only part you may have a problem with is resetting the fluid change counter (Photo 3).
[IMG]local://upfiles/4491/5C842AC3287A4906A944ED77BE54ACA0.jpg[/IMG]
[IMG]local://upfiles/4491/13C7A2B3D8DE4A7183C1422EF0291DF7.jpg[/IMG]
[IMG]local://upfiles/4491/FADEDA29229946AC9F388933E1B101F8.jpg[/IMG]
[IMG]local://upfiles/4491/9A1748EA4D154D6C8E9096C5E01F604A.jpg[/IMG]
[IMG]local://upfiles/4491/C91458CB46BC49B78FBAAC1DFFF6EE87.jpg[/IMG]
Old May 8, 2007 | 12:22 AM
petter shoemaker's Avatar
Try this: http://s40concepts.net/forum/index.p...64ca6d274e49f7
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
shop2
Nov 1, 2011 08:56 AM
jjc*
Dec 5, 2008 06:35 PM
shadowlord
Apr 8, 2008 08:37 PM
Glenn B
Feb 19, 2008 04:57 PM
