Sponsored by:
Sponsored by: DashLynx
'05 s60 rubbing noise on tight turns
Old 01-11-2013, 03:41 PM
LiteWait's Avatar
Default '05 s60 rubbing noise on tight turns
I've noticed a rubbing noise when I make tight slow turns (say when turning around). I seems to be like the tire rubbing against plastic. Too cold out now or I would do further debugging. Any ideas?
Old 01-11-2013, 04:45 PM
J. A. Higgins's Avatar
Check if the limiter has been removed. Many people remove then to gain more radius when turning. For location, the limiter is attached to the cradle that bolts to the brake caliper.
Old 01-11-2013, 05:04 PM
Mad Matt's Avatar
Yeah, more then likely the steering stops are worn out. Or it will also rub if you've put wider tires on your car.
Old 01-12-2013, 09:36 AM
Ritsuke's Avatar
Mine has the same problem but only when turning (fully) left. When doing the same to the right hand side I have no problems. I guess my bet is the "worn out" reply of this topic?
Old 01-17-2017, 11:07 AM
PineTree's Avatar
Default 2006 s60 rubbing
Hi, I'm resurrecting this old thread.
Both front tires on my 2006 s60 rub on the wheelwells at full turn. The left tire rubs when turning full right, and the right tire rubs when turning full left, so it's the leading inside edge of the tire that rubs on the front inside of the wheelwells.
I've been reading about steering limiters, and will look at that first, but I remember seeing there is the possibility of something worse going on.
Fingers crossed it's a simple fix of swapping the steering stops from each side....
Iggyomega
04-10-2020 07:23 AM
Sofar.
01-14-2014 01:42 PM
Stb7
11-06-2013 09:12 AM
Dj Eterno
03-13-2008 07:53 PM
Quick Reply: '05 s60 rubbing noise on tight turns
