06 s60 2.5t feels sluggish
I just replaced the engine on my 2006 Volvo s60 2.5t and i am concerned with the result. The car is not as responsive and feels really down on power. I checked to see if there was to much oil in the engine and there was, but only about a half a liter. Would this cause such a drastic loss in power? Is there anything else that could be causing this problem?.
I'd start with the basics first . Check compression,plugs, clean MAF sensor, check fuel pressure and regulator along with all related boost items. Plumbing and so on. Running a vac me gauge can revile a misfire all sorts of issues. Even PVC ....
I've also had bad injectors spraying a stream instead of a fine mist. Caused a rich flooding condition on two cylinders.
