2001 S60 T5 Transmission ?
[quote=Roy Rogers;288556]2001 S60 T5 Transmission hesitates going from 1st to 2nd and is getting worse. Is there common cause to this that can be easily fixed or does it need to be replaced? Thanks for any help![/quot
There are know issues with 01-02 tranys. Have not seen a T5 posted but my guess that its the same Transmissions. First look at replacing trany fluid.Flush kit from IPD and 12 qts of Volvo JWS 3309/mobil 3309/toyota t-iv ONLY do not let any one tell you that any other fluid can be used.You can also check with Volvo deal for software updates and i believe its a B4servo cover repair can be done.But this may all be for nothing in most cases when the trays starts to skp/slip its to late to do anything but replace.Dealer will use New trany $4500 with labor.Find a local Volvo shop and see if you can have a used one or even a rebuilt one used.GL
Was your acting up as mine is when you did the flush? If so all is well now? Thanks
How many miles do you have on your s60? Did you check the state of your ATF? is it dark and have a burning smell? Is your level of ATF not too low? This can be easily checked by looking at your ATF dipstick. If the ATF looks dark (it is supposed to have a clear reddish color) and has a burning smell I would definitely try a flush first. My 2cts
Great company for OME and Performance parts
