Looking for: How-to on how to change timing belt and water pump
Old 10-06-2011, 11:15 AM
Maximus from the 915's Avatar
Default Looking for: How-to on how to change timing belt and water pump
Hello all, I am wanting to change my timing belt with tensioners and water pump. How difficult is this? I have replaced a water pump on a Mustang before but never worked on a timing belt. Is this something relatively straight forward or should I take it to a shop? I couldn't find anything using the search function. Thank you.
Old 10-07-2011, 03:31 PM
MYS6T's Avatar
This is not a job to do as the first time. The job is straight forward if you have replaced a TB before. Make sure that you replace the idler Pulley as well . The belt is not what fails most time its the tensioners/pully. Look at European Car Parts Online Catalog & Free Shipping | FCP Euro great deals on the whole kit .i suggest that you replace the water pump at the same time. Then find a local shop that will allow you to use your own parts. Its a 3 hr or so job. There was a you-tube Vid that some one made doing the TB on an S60 R but i cant seem to find it now. They are just about the same as far as what needs to be done. GL and be careful if you decide to do this yourself.Not a job that can be done any way but 100% right or No more car.
UnSafe
08-23-2015 06:34 PM
majorcode
11-04-2013 06:41 PM
ylwgto
09-22-2011 12:55 PM
kingmf
02-17-2010 10:07 PM
95volvo850
09-16-2009 09:30 AM
Quick Reply: Looking for: How-to on how to change timing belt and water pump
