Sponsored by:
Sponsored by: DashLynx
Brake Failure Warning Fix?
Old 11-23-2014, 06:02 AM
mortenmorfar's Avatar
ES6T easy now, I don't think Pyro71 is racing.
if there is a bad reluctor ring or speed sensor, the car will see that the speed doesn't match the other wheels, and then it turns the traction control on to try and get the wheels going at the same speed again.
  #22
Old 11-23-2014, 06:27 AM
ES6T's Avatar
It will not stall the engine.
And I didn't mean him specifically. I meant if someone spins their wheels because they are trying to beat a car through a turn, the blame is on them.
  #23
Old 11-24-2014, 04:13 PM
pyro71's Avatar
Originally Posted by ES6T
You said the engine cut out. The traction control does not kill the engine.
If you had to mash the gas to make the turn and spun the wheels, maybe you shouldn't have made the turn. Trying to speed through can cause wheel slip in any car. Driving like that will get you killed- not the traction control.
The traction control cut power(not engine) to drive wheels completely for about 3 seconds. I'm sure you can understand the dangers of that happening in any situation but especially in the situation I described. Whether that situation is prudent or not is important here as I believe it is a common situation that the OP should be aware of. Thanks for clarifying that the engine did not stall but power was not available due to traction control/abs failure.
theotherpilot
07-10-2009 12:28 AM
rbmill2
06-27-2009 09:44 AM
kosmoscanyon
12-16-2008 12:39 PM
Volvorator
03-15-2007 10:37 AM
Quick Reply: Brake Failure Warning Fix?
