Camshaft Position Sensor broken cap???
Old Oct 10, 2010 | 07:07 PM
burtonpas's Avatar
Default Camshaft Position Sensor broken cap???
Hi,
I have a 2003 Volvo S60 T5 2.3L. Today I tried to change the Camshaft Position Sensor but when I tried to I broke the cover on wich the sensor connect to.
The problem is that I can't find on the web the name of that part. I will attach some pics, if someone can help me that would be great!
Thanks a lot!
Attached Thumbnails Camshaft Position Sensor broken cap???-sany0318-custom-.jpg   Camshaft Position Sensor broken cap???-sany0320-custom-.jpg
Old Oct 11, 2010 | 02:55 PM
dsharp's Avatar
Default sensor housing
I think its listed in the ignition group- listed as a "housing" . Unless updated it's part # 30637087
Old Oct 12, 2010 | 09:47 AM
burtonpas's Avatar
Thanks for the info, just order the part from Volvo in Quebec
Old Oct 13, 2010 | 09:56 PM
burtonpas's Avatar
I just replace the Camshaft Position Sensor and still got the same problem, car is long to start and pull code P0340.
Can it be the Crankshaft sensor now?
First time this happen was 4 days ago, pull code P0340 and P0016, now P0016 seems to be gone.
I also tried with the old Camshaft Sensor, got code P0340 but not P0016. Haven't drive the car, just let it run in my garage.
Help would be greatly appreciated
Old Oct 14, 2010 | 07:23 AM
burtonpas's Avatar
Just to follow up, i put the multimeter on the camshaft sensor plug. i read 5v on pin 1 and 3 with ignition on. is that normal?
Old Oct 14, 2010 | 03:48 PM
Manu Noypi's Avatar
So was the part no. given the correct one. I also broke mine when I overtightened it so need to order one. Read somewhere that the hard starts could be caused by metal shavings covering the crankshaft position sensor. Try cleaning that sensor and let us know.
Old Oct 14, 2010 | 06:50 PM
burtonpas's Avatar
The number part was good, if you have a 2002-, if you have a 2001 T5 it's not the same.
I order a crankshaft sensor today, will received it tomorrow. I removed the old one a couple of minute ago, I put the multimeter on the two pins, I have a reading of 122 ohms, I don't know if that value tell the part is defect or not? Someone know?
Old Oct 14, 2010 | 07:46 PM
burtonpas's Avatar
update: I check the voltage on the crankshaft sensor plug while my girlfriend was cranking, I got 2.5V on each of the two plugs, I don't know if that is normal.
I also check in the Vadis, the resistance of the crankshaft sensor between the 2 connectors should be between 108.5-142.5 Ω at 20°C. I have 122 Ω.
Not sure if my new crankshaft sensor will correct my problem. I don't know where to look now
Old Oct 19, 2010 | 11:05 AM
burtonpas's Avatar
Anybody as any clue what to look next?
Old Nov 5, 2010 | 04:42 PM
bgumis's Avatar
Hi ...i have the same problem with P0016...did you find the solution ?
Old Nov 8, 2010 | 04:05 PM
the_brain3000's Avatar
i had code p0016 too and replaced both crankshaft and camshaft sensors
according to the shop's suggestion.
never had starting problems as i replaced it right away but it was a matter of time i guess.
the crankshaft job cost me a lot as it was harder to get too but if you can it yourself you shouldnt spend more than what you pay on the parts so it's worth to try.
good luck!
Old Nov 9, 2010 | 06:20 PM
Manu Noypi's Avatar
burtonpas, did replacing the cranksahft pos. sensor solve your hard starting issue.
Old Nov 11, 2010 | 10:46 PM
griffinlinks's Avatar
You might consider changing the camshaft position solenoid. It can cause similar conditions. It takes about 10-15 minutes to change.
Old Nov 26, 2020 | 05:46 PM
Marc Xyoung's Avatar
Default Name please
Does anyone know the name of that metal piece that spins that sits behind the camshaft pos sensor housing? Mines chipped and I think that's what keeping my car from continually running when started. Volvo s60 2003. If it's easily replaced I rather fix it myself.
Old Nov 26, 2020 | 06:20 PM
something like this?
https://parts.volvocarsannapolis.com...IaApP2EALw_wcB
Old Nov 27, 2020 | 11:35 PM
Default Is it as easy as it looks?
Does anyone know if replacing the aperture is as easy as it looks? Is it just a unscrew it and screw a new one in situation r is there more to it?
Old Nov 28, 2020 | 08:18 AM
  #17
That’s it - one bolt, only fits one way
Old Nov 28, 2020 | 10:33 AM
  #18
Thanks good sir, I appreciate it.
ysunshine
Nov 3, 2020 05:00 PM
Maddog812
Oct 18, 2015 07:38 PM
Alighee
Jul 25, 2011 02:58 AM
rupert77
Jan 26, 2009 06:34 PM
EmailBenn
Apr 11, 2006 10:18 PM
