Cooling water issue - 2014 S60
Hi All!
I have a problem. It started approximately three weeks ago with a computer alert: "The level of the cooling water is low". I didn't understand it because a car is quite new but I checked the cooling water and approx. 1dl of water was really missing! I looked for any leaking problems but couldn't find anything suspicious.
I have replenished the cooling water and after this there was no any problem or alert until the next week. The car alerted again after a week and there was a shortage again!
I absolutely don't understand this phenomenon. There is not any sign of any kind of damage. The engine and everything inside the engine bay looks perfect and clean! The cooler looks OK as well. I have no any ideas what could it be.
Please help me!
Thank you Guys!
Please help me!
Thank you Guys!
I know the warranty, but if I take it there I will miss the car for at least one or two days and I need it every day, it's very important.
That's why I would like to solve this issue by myself, if it's possible. But of course, if I can't find the problem I will have to take the car back to the dealer...
damien,
Don't get me wrong, I just wanted to know somebody has ever experienced this issue, and can tell the origin of this. And if it's possible I try to avoid the dealer who is not as kind as yours, and I don't really want to reorganize my days which are actually quite busy in this period. So, if it's possible to find out something by sharing this issue with other owners who has the same car I choose this way at first, but I know nobody can repair or fix something over the internet. Of course, if there won't be any solution or suggestion I will go back to the dealer, and there's my warranty too.
I have the same problem 2013 9 months old v40
my car is still is in service.
no leaking but dirty coolant.
low coolant but no overheat.
firstly changed waterpump under warranty after 1k again same problem.
now in service. engine opened head gasket sent to repair and test.
im still waiting. they can not find problem yet.
is it a chronical problem that just appear with new d2 engine.
so disappointed with my first volvo.
I surmised I'm not the only one who experienced this issue.
So you say they could'n find anything in the service yet? It's a really big mystery because I don't see any leaking too and wouldn't think there would be any problem with the gasket, but this is just my opinion.
Anyway, I'm not disappointed with this Volvo. I think it's a really good car, I enjoy driving it every time I get in the car, behaves good at big distances as well and I could tell much more good things about it.
So, I hope the problem will be fixed.
When you said "dirty coolant" you meant there is something dust in the water?
And you have noticed a lower coolant level as well...
Interesting.
yeah I got my car and I miss my car
firstly pressure test failure . this is because of no leaking outside. the test will be success under the condition of outside leaking.
but where is the water going?
there was a beard on the head gasket. and water is not going to cylinders but because of vaporisation coolant level is going low.
what did service do?
head gasket shaved. now no leaking or no problem.
everything done under warranty so its fine. but it takes too long to repair. 4 weeks without volvo..
And which gasket is affected now exactly? It's important!
Four weeks, that's a long time. I don't understand why does it take so long.
Wowowowo! I probably misunderstand something, but where was the small hole exactly? I think you mean a small, tiny rift or hole on the gasket, am I right?
head gasket sent and brushed thats why now system is working regular.
today I have another problem electric mirrors are not working..
anyone have any idea?
I read some forum about fuse but I dont think that I can find that fuse.
unlucky me..
over heating
ok i have a 97 850 glt 5 cyl turbo
i have recently begsn haveing over heating issues with it have repalced both thermostat and coolant temp sender
car run cool till get on frwys
i do not have any leaks positivly no water in oil and no steam from tail pipe
but after 20 miles of frwy i am low on water and over heating
i have have good flow so cant be clogged rad fan runs in high and low
this is my second post about this i hope someone wil reply this time
#17
There is not a hole. it is like a hair crack.
unlucky me..
unlucky me..
The mirrors?! Oh man, you really unlucky. Sorry for that. :-)
The fuse is a good idea, I think the same. Had a fuse problem with the cigarette lighter, and my friend had the same problem in his A4. Try to change it!
#18
What do you mean under frwys?
#19
