Cooling water issue - 2014 S60
#21
well no and yes before i was able to drive at about 65 75 no problem
but now its heatin up try to keep it a steady 60 65
but im in los angeles area so speed can vary a lot depending on time and direction im traveling in
even tried driveing with heater on and blowing at max didnt help either
#22
measuring coolant depends on mileage that you do
first of my coolant alert they changed water pump after 1.5 k km alert came again and then they decide to open engine
I think they need to test system but we don't have overheating problem but you have, so you must take an action asap.
overheating may occur you a huge problem.
#23
I remember, many years ago I have tried to keep down the temperature of the coolant the way you said, that was useless I don't have to say.
Your problem is a miracle as well. I will try to get some info about that and respond to you.
#24
#25
thats miles per hour not kilometers
#27
