Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S60
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 06-28-2009, 03:28 PM
Default Fuel Filler Door Won't Open
Hello, All. I am new to the forum. I am just a housewife trying to figure out why my fuel filler door won't open on my 2002 S-60. I have replaced the fuse. Can anyone tell me what else I can try? Thank you!
Old 06-28-2009, 03:33 PM
Also, I think it might be the relay, as that would be the next logial thing to me - I see the dash panel pops out - but can't figure out how to pop it out without breaking it!
Old 06-28-2009, 04:25 PM
1995 Volvo 850
My Garage
Send a message via Yahoo to rspi
Not 100% sure but my 850 has a pin that goes through a lever on the door. Maybe it is getting stuck because the lever is bent or something. Put a little pressure on it (in pressure) then have someone push the release then let it go and see if that will help it get un-stuck.
Once you get it open, you may want to leave it open until someone fixes it.
__________________
'95 850 T-5R Wagon - Panther - Daily Driver 22 / 28 mpg
'98 S70 GLT - Lil' Red - Daughter 22/30 mpg
Volvo Repair Videos - Used Parts For Sale - Interior Lights For Sale - ABS Light? Click Here - Men's Mentoring
Volvo's of time past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow, '95 960, ,96 850 R...
Old 06-28-2009, 07:03 PM
Well, that was a good suggestion, but it didn't work Is there a way to pop it open manually so that I can temporarily get gas??? Thank you so much!
Old 06-28-2009, 07:05 PM
I mean feul! Ha ha ha! Don't want gas!!!
Old 06-28-2009, 08:49 PM
Well, I popped it open through the trunk so I am able to get it open. I think it is the little motor there in the back right next to the release. It looks like it just pops out.....Yeah! I think I figured it out!
Old 12-21-2009, 06:38 PM
This happened to me while out of state on a business trip. Thank goodness I had enough gas to get me to a local Volvo dealership and they were able to help me by doing the following.
1. Put your key in the driver's side door and turn it to the left TWICE.
2. Then turn the key to the right TWICE.
According to the gentleman at the dealership, these two steps "reset the system" and I was then able to push the release button and the door was unlocked.
It has happened to me more than 3 times since then and doing the previous steps fixes the problem every time.
I hope this will work for everyone who comes into this unfortunate delimma.
Old 12-27-2009, 12:55 PM
mcleantmw's Avatar
As you discovered, there is a pull cord in trunk next to the filler door that will manually release the door. I replaced fillor door lock unit on my 2004 S60 recently. When you drive the vehicle, the filler door lock is supposed to lock and the release button is supposed to release the lock unit. Since you released the lock manually, check to see if the door relocked when you drove the vehicle. If it didn't, it could be the lock motor is defective and needs replacement. If it did relock, and the release won't work, then it's some other problem with the electrical system that releases the lock motor.
__________________
My Vehicles
Mercedes 2003 E500
Volvo 2001 V70 2.4T
Volvo 2004 S60 2.4
Volvo 1989 740 GL Wagon (deceased 2/2009)
Old 05-21-2013, 10:15 AM
Default Worked Perfectly !!!
Worked Perfectly !!! Thanks
Tags
2000, 60, back, door, filler, fuel, gas, open, panel, s60, s80, stuck, v70, volvo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford is a registered trademark of the Ford Motor Company.
Secure Backup
