Grinding noise on my Volvo s60 2001 Turbo
Old 04-08-2014, 12:02 AM
Manasa Lesuma Senior's Avatar
Exclamation Grinding noise on my Volvo s60 2001 Turbo
Hi All,
Hope everyone is having a good day
I have a whistling noise from the Serpentine belt area that is very loud.I changed my tensioner today and even fitted in a new Serpentine Belt and the noise didn't go away.
Any suggestions, please?
Last edited by Manasa Lesuma Senior; 04-08-2014 at 12:03 AM. Reason: tensioner not idler
Old 04-12-2014, 07:36 AM
Magnus308's Avatar
Originally Posted by Manasa Lesuma Senior
Hi All,
Probably your alternator that starts to go bad, But also check the powersteering fluid level.
If you have not replaced the oetiker clamp on the hose under the reservoir you will have a leakage there.
The powersteering oil reservoir can also be broken, open the cap and check that the oil return tube inside the reservoir
have not become broken off and is on the bottom of the reservoir and prevent oil to come to the powersteering pump.
Old 04-12-2014, 07:32 PM
oragex's Avatar
also check you have the right p/s fluid that is, light green
anjp
10-21-2015 04:25 PM
ptownsoldit
06-26-2009 03:38 PM
cjjtc
02-18-2009 08:31 AM
elguzzy
11-16-2008 12:49 PM
rantiddlybobo
04-11-2004 12:47 PM
Quick Reply: Grinding noise on my Volvo s60 2001 Turbo
