Thats the first question what type of fluid.I hope it has JWS3309 specs ?This car should be drained/filled Via the Radiator 2qts. out 2 qts in Im not sure what Power flush is/How many qts did they use.The trany takes 12 to do a complete flush.But other than that 1st check your lower trany mount.The bushing can go and the trany will slip.Most times 2-3.Its located front of the car you will see the bushing almost middel just in front of the skidplate.If that looks ok call the stealership in your area with your VIN and see if theirs a software update for you car.I just went threw a Trany issue that almost had me replace the Trany but all it needed was the update.$4500 for new Trany or $80 for update.
__________________
03 S60 AWD Geartronic 2.5T W/Elevate(AutoTech)Stage2,,OBX 3"catless DownPipe,OBX R Exhaust,Snabb FA Pipe,ARD tcv,Est HiFlow intake,IPD (CBV,CoilPacks)
