Sponsored by:
Sponsored by: DashLynx
Fuel Pressure Regulator - Same thing as Fuel Pressure Sensor?
Old 11-19-2013, 01:49 PM
MntnDewMan's Avatar
Default Fuel Pressure Regulator - Same thing as Fuel Pressure Sensor?
Hi guys - I'm new to working on my 2005 Volvo S60. I don't know a lot about cars, but i'm learning as I go. Tired of paying for expensive shops to take care of a job that I can figure out myself.
Just have one question...if I'm ordering a part, the "fuel pressure regulator," is that the same thing as the fuel pressure sensor/switch on the right side of my engine?
Thanks!
MDM
Old 11-19-2013, 01:59 PM
MntnDewMan's Avatar
Never mind all - just found my answer! They are NOT the same thing.
MDM
Old 06-16-2017, 04:32 AM
VolvoMasochist's Avatar
And for more confusion, Volvo calls them "Absorbers". For example, on a first-gen S80, you find images of part # 9186278.
Old 06-17-2017, 05:30 PM
On the newer models, the fuel pressure sensor is used to regulate the fuel pump and the regulator is used to dampen the changes in pressure level. On older models, the fuel pump is running at one level and the regulator uses the intake vacuum to dampen and retain pressure.
Old 06-17-2017, 09:36 PM
Default Clarifying "newer" versus "older"
Agreed, and to clarify, the (up-to-18-year-old) 1st-gen S80 is a "newer model" in the context of the above comment. (I don't know if this regulator changed between the unfortunate introductory 1999 model year and my 2003.)
Old 09-30-2018, 03:28 PM
JoyfulThoughts's Avatar
Default Volvo fuel pressure damper 9186278
Can someone please help me locate the fuel pressure damper/regulator on a 2006 Volvo S80? I have the part number 9186278 however can not locate where to replace. Please help!
Old 10-02-2018, 02:05 PM
try googling volvo 9186278 - my guess is its either under the fuel rail or under the intake manifold
Old 10-02-2018, 06:19 PM
I pulled my VIN and found my motor B5248T2 and the service manual shows it right on the fuel rail... only problem, it's not there nor a place to plug it in. :-(
Old 08-14-2023, 06:17 PM
GLE's Avatar
GLE
GLE is offline
I have a 02 v70xc that will not start. I have 60lbs of fuel pressure when cranking but drops to 0 as soon as you turn off key? Any answers?
Old 04-03-2024, 04:05 PM
Bigbishop's Avatar
Same as mine. Immediately I turn the car off, pressure drops to zero in less than 2 minutes. Changed fuel pump only (without assembly), fuel filter, spark plugs. Car still takes a few cranks to start. I am thinking either injectors or pump check valve. Did you get it sorted out? Mine is 2003 S60 2.5T
Daniela Alexe
09-16-2021 01:28 AM
ArtMan
05-11-2018 08:50 PM
Brian Shapiro
Penta
07-20-2017 05:53 AM
the tenor man
12-05-2011 09:20 PM
soapboxhero
10-12-2006 03:19 PM
Quick Reply: Fuel Pressure Regulator - Same thing as Fuel Pressure Sensor?
