Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S60
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 12-20-2009, 02:23 AM
Default How to change Low Beam
I have 2006 S60 2.5T. I try to change driver side low beam. But it is very difficult to access the bulb as manual mentioned. Is there any trick? I can just put my hand in and touch the wire and can not use any force to pull anything out.
Old 12-20-2009, 07:46 AM
They are kind of a pain. But you need to just work your hand around to get to them.
__________________
1987 Ford mustang LX Coupe 5.0
1995 Yellow T5-RM running
1996 850 turbo
1994 N/A 5-speed wagon Purple (daughters)
Old 12-20-2009, 09:26 AM
turn your hand into a claw
__________________
2002 S60 T5 Manual - Eurosport Tuning Ultra-Flo Intake - H&R Lowering Springs - Bilstein HD Sport Struts and Shocks - Evolve Exhaust - QBM Strut Tower Conversion - Rica Stage 1 Tuning - Bits and Pieces of look good parts.
Old 12-20-2009, 05:24 PM
Quote:
I'm doing the exact same thing & I have a huge hand, but if you look there is a copper colord colored retaining clip that go's over the black light socket & is clipped at the top, if you can unclip it you should be fine.
My problem is that I knocked the retaining out of it's little holder & can't seem to get back in.
Old 12-27-2009, 01:20 PM
mcleantmw's Avatar
You need to remove the black female push on electrical connector first from the two male prongs of the light bulb........wiggle it off without pulling too hard. Then you can get to the pressure spring clip that hold the bulb tightly into the fixture........the top of the spring clip needs to be pushed in and out around the clip groove. Once the clip is unclipped, it pivots down and you can get access to the bulb..........note the raised groove at the top of the bulb............make sure the new replacement bulb is inserted with that raised groove at the top, not the bottom, or it will not seat correctly. Reverse the process to complete the install of the new bulb.
__________________
My Vehicles
Mercedes 2003 E500
Volvo 2001 V70 2.4T
Volvo 2004 S60 2.4
Volvo 1989 740 GL Wagon (deceased 2/2009)
Old 12-30-2009, 11:48 AM
Default Finally I figure out
Thanks all,
I finally figure out how to remove the S60 2006 2.5T USA model driver side low beam. The service manual is wrong. You don't need remove the connector and there is no clipper. Just turn the whole low beam to counterclockwise 90 degree. Maybe clockwise works also. I wonder why Volvo don't give us correct method? Hope my experience will help you. Today my passenger side low beam is broken also. I will change it today.
Old 04-27-2013, 02:23 PM
Thanks to davidgu0186. You verified what I was noticing. No clip, and you can only remove the connector after you get the bulb out. I spent 45 minutes trying to get the bulb back in, and an extra 45 SECONDS after reading your post about the 1/4 turn. (2005 V70)
Not sure but Maybe there isn't a mechanism that you are turning the bulb into; the 1/4 turn might just be a method to coax the rubber sealing gasket into seating into the hole.
Old 12-19-2013, 07:19 PM
I have the same exact car and the same bulb that needs to be replaced. Can you of you comment on how the low beam bulb looks? I haven't pulled mine out yet, but my manual says it should have 2 prongs, almost like an H7 even though it says the low beam is an H11. I bought an H11 but all the H11s on the market have these right angle connectors on them more akin to high beam bulbs.
I made a thread about this, sorry, I'm just in a bind here.
Tags
2004, 2005, beam, bulb, change, light, lightbulb, low, lowbeam, replace, s80, volvo, wire, xc70, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
