Sponsored by:
Sponsored by: DashLynx
Need help on door wiring
Old 08-20-2014, 06:19 PM
alpac's Avatar
Default Need help on door wiring
Hi folks,
My daughter got a big dent in the passenger front door of her 2004 S60 2.5 bad enough for the door to be replaced. This is too bad because otherwise her car is pristine, it used to be mine before I gave it to her. Anyway, I was very lucky to find at a junk yard a used door from a 2002 V70, same color, great condition with everything already on it (window, actuator, lock, etc...) so no need to swap anything which saves a tone of work and time. I was hoping to be just plug and play. However the new door is fed from the cabin with 9 wires connection while the S60 damaged door only has 7 wires coming from the cabin. I am thinking may be the V70 had heated mirror and the S60 does not which would explain the difference in wiring but this is just a guess. Does anybody know if the door wiring of a 2002 V70 is the same as a 2004 S60? Any suggestion you may have would be greatly appreciated. Otherwise I guess I am going to have to trace each wire or try to find a door wiring diagram for both cars and compare.
Thanks a lot in advance
Al
enoble
04-29-2011 05:07 PM
Echoe
08-26-2009 12:08 PM
Echoe
Engine & Internal
08-20-2009 12:07 AM
vic420413
12-12-2006 08:38 PM
Quick Reply: Need help on door wiring
