Sponsored by:
Sponsored by: DashLynx
erattic engine.
Old 11-13-2010, 12:28 PM
soodala2k's Avatar
Default erattic engine.
I got a 2002 S 60 with 65k miles on it. I can't believe the engine started to be problematic. When I accelerate between 1500 and 2000 RPM , it whines and a check engine light turns on. I took it to a dealer and they said it needed a software upgrade. On the very next day the engine light came back and stayed for a while then went away. The dealer said they need a engine light to be on to check. The light has been on and off and whenever I call them they said they are full and I have to wait and depending on their findings, they will charge me again. I will never buy any volvo and won't go to a dealer again. For me, volvo is a lemon.
Old 11-13-2010, 01:28 PM
2001s602.4t's Avatar
you can not let one bad thing run u off volvo makes a good car. any thing u buy will have problems. bmw saab ford chevy thay all use the same parts and are made the same ways. good luck with the car
Old 11-13-2010, 02:21 PM
Manu Noypi's Avatar
There's a recall on ETM on these models so do your research.
Old 11-13-2010, 04:41 PM
soodala2k's Avatar
Default oily spark plugs
Today I pulled out all spark plugs and noticed oil at the threads of all plugs. I wonder why in the first place the dealer couldn' find this, while relying on only computer scan. I think I need a new valve cover gasket.
Old 11-14-2010, 07:03 AM
check the oil cap seal thay dry out and leak down in to the wells
Old 11-14-2010, 02:52 PM
Manu Noypi's Avatar
U have to clean your pcv w/c is possibly clogged. While engine is idling, pull out oil dipstick and see if smoke is blowing out of it. If it is, then pcv job shld be done.
Old 11-15-2010, 06:03 PM
850_96's Avatar
is it a turbo S60?
Old 11-15-2010, 06:37 PM
soodala2k's Avatar
Originally Posted by 850_96
is it a turbo S60?
no , it's a base.
Old 11-16-2010, 03:37 PM
850_96's Avatar
damn.. im looking at S60 non turbos.. hoping they are better than turbos, reliability wise and issue wise. :/ .. Good Luck with your S60!!
tngreg
09-05-2022 07:27 PM
gravedigger
03-10-2007 11:27 PM
sbrownbw
09-23-2005 09:49 PM
Quick Reply: erattic engine.
