pricing for software upgrade?
Old 03-25-2008, 09:31 AM
ryama's Avatar
Default pricing for software upgrade?
So i have read if you have a problem with an S60 where the transmission will slip occassionaly and the RPM's will go crazy and that you should take it to a dealer have them do a software upgrade. Anyone whon has done this, how much does this usually cost, will it vary depending on my location?
Old 03-25-2008, 11:35 AM
mkaresh's Avatar
Default RE: pricing for software upgrade?
Are you out of warranty? If not, it'll be free.
If so, I'd expect to pay $200-300 based on what I hear it costs with other cars. As with any repair, it'll vary from dealer to dealer.
Old 03-25-2008, 01:35 PM
Software typically runs about $35.00 U.S. with about 1/2 and hour for labor. Atleast that's what my dealer charges.
Old 03-25-2008, 03:44 PM
Have you considered a full system reset which is FREE ..just remove battery overnight and let car re-learn again..usually in Uk dealers upgrade software each time car is in for service
Old 03-25-2008, 05:01 PM
ryama's Avatar
a full system reset.... so does the time i have the battery unplugged have to be exact?
Old 03-26-2008, 11:27 AM
or the quick way, disconnect the battery and touch both negative and positve leads together for 2 mins.
Old 03-26-2008, 01:03 PM
ORIGINAL: Volvo801
I wouldnt recomend that..there is chance you will set of SRS light doing that..
Old 03-26-2008, 03:52 PM
mkaresh's Avatar
ORIGINAL: Bigtrev
This is much more reasonable than I've heard for other cars.
Old 03-27-2008, 06:50 AM
2002v70's Avatar
The software upgrade will not fix the "shift flare" and the delayed "drive" engagement. This is the valve body in the transmission that is defective. The earlier design was flawed and Volvo (Aisin Warner) has since come out with a redesign. The part is about $900.00 and labour is about 4 hours. Do a search on this forum. I have pictures posted of the 2 different valve bodies.
The software upgrade does need to be done with the new valve body install so try it first, but you most likely need this repair as well.
Here are some links to more posts on the subject:
https://volvoforums.com/m_79509/tm.htm
https://volvoforums.com/m_2138/tm.htm
fmscott2
05-11-2011 12:03 PM
woodkayakr
12-03-2009 05:10 PM
johnb311
07-16-2009 09:44 PM
ryman1980
04-15-2009 12:05 PM
S70driver
05-15-2006 05:02 PM
Quick Reply: pricing for software upgrade?
