Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S60
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 01-25-2009, 02:06 PM
Default Rough start in cold
I have a 2004 Volvo S60 T5 that his very hard to start in cold weather. When I turn the key, it turns over, but won't catch. If I hold the key over for about 3 or 4 minutes, it eventually catches and starts running. Once running, it runs perfectly. And once it's warm, you can turn it off and restart it with 0 problems.
I've spent $1200 so far on this problem and three different garages can't figure it out and fix it. It seems that when cold, the car floods the cylinders immediately. It's then me cranking through this flooded state to get it started, the gas burns out, then runs fine. Two out of three mechanics got some readings that compression seems to be low in certain cylinders. Perhaps until oil gets up on the cylinder walls, compression is low, then later when it warms up a bit, compression is fine.
One mechanic had my car in the cold over the weekend with the temp sensor unplugged and hose disconnected (whatever the hose is that passes over the spark plugs). when he turned the key, it started immediately. He turned it off, plugged the sensor in, hooked up the hose and tried to start again with no luck. Weird. This behavior has never been duplicated.
One other thing. The fan on the car runs continuously from startup and the entire time the car is on. I live in Pennsylvania and it's in the 20's here.
Can anyone give me any ideas? Thanks a million!
Tags
cold, d5, hard, rough, runs, s60, start, starting, starts, volvo, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
