Sponsored by:
Sponsored by: DashLynx
S 60 Trans Help needed
Old 04-10-2014, 08:56 PM
Greenmudshark's Avatar
Default S 60 Trans Help needed
Guys, I have a 2002 S 60 Volvo non turbo that has 103,000 miles on it.. When I start the car up in the morning and put it into reverse-- it goes right in gear-- no problem---- but when I shift it into drive it hesitates then jams in gear with a big bump. Is it time to send this car down the road?? or can I have the trans serviced to get more life out of it???? ( I would like to keep this car) Thanks Mud
Old 04-11-2014, 07:07 PM
difflock54's Avatar
How clean is the transmission fluid?
At that mileage it would be due for changing if it is the original fluid.
Do a drain and fill procedure. NOT A POWERFLUSH.
If you have an AW55-50SN transmission you need to use a JWS3309 spec'd fluid.
Many report much improvement and smooth changes shortly after doing a fluid change but it could also be a shift solenoid problem.
Worth getting the car checked for especially transmission related fault codes prior also.
Old 04-11-2014, 07:19 PM
oragex's Avatar
Its technical but it has your answer
transmission issues
Old 04-12-2014, 02:47 AM
stop_at_willoughby's Avatar
Certain 01 and 02 Vovlo's the s60 being one of them are plagued with transmission slipping issues. You can spend $200 to have the transmission fluid replaced. More than likely it won't do anything.
Look at the thread the other member posted above. But you are either looking at a rebuild or having to purchase a salvaged transmission out of another car. I would again avoid 01 and 02 cars for the P2 Chasis (v70, S60, S80).
I went through this same situation my 02 s60 about 4 years ago. I bought a salvaged tranny out of a 03 V70.
nortons
02-22-2015 11:14 PM
VolPat
06-15-2012 08:06 PM
ded137t5r
06-10-2012 07:40 PM
Eric's Hot Rod Shop
07-14-2011 08:26 AM
VTBricked
11-21-2009 07:50 AM
Quick Reply: S 60 Trans Help needed
