tail brake lights on when driving
Hi guys I have problem with brake lights they came on after big rain and I managed to turn them off but now when car is on lights are on all time,brake light switch is ok and it is working when car is off, fuses are ok, REM I can not check and CEM same thing, I do not know what else to check thank you.
The more you write about it the more I think your rear fog is on. You need to post a picture.
The brake lights are indipendant of the car running. You can get in a car, press the brake pedal, and the brake lights will come on. Has nothing to do with the car running. If you have a brake/cruise cut off switch malfunctioning, maybe they can come on when the car is running but I doubt that.
88740gle
11-13-2015 08:13 AM
buellfire
06-20-2009 12:37 AM
