Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S60
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 08-26-2007, 11:08 AM
Default S60 won't start when low on fuel??
hey guys, this is the second time this has happened, basically I park the car when it's low on fuel, as in gas light is on and it saysd 60mi to empty. Then I try to start the car and it just cranks. today the car happens to be parked on a slant, but the last time in was in it's own level parking spot. I guess, i shouldn't let it get that low but I was just wondering why it would run, then not restart. The message console says," Start prvented retry", is this due to no fuel?
I'm going to dump some gas in the tank and try then, I'll let you know. Thanks.
__________________
'02 Volvo S60 2.4T AWD - RICA Stage 2 ECU, TDO4HL-16T Upgrade, R Manifold, K&N Cone, IPD HD TCV, OBX 3" DP, EST 'R' Catback, Custom FMIC, Eibach Pro Kit, etc...
Old 08-26-2007, 11:57 AM
Default RE: S60 won't start when low on fuel??
Well I poured in a gallon or so of fuel and tried to start it, it kept saying start prevented and then started to read ,"Reduced Engine Performance". Well, needless to say i gave up and pushed it fdown the driveway a bit to it's regular parking spot, thinking I was going to have it towed to my mechanic for some crazy Volvo diagnostic work. Well, as I back it into it's spot I decided to gibve it one least shot and cramnked it, the engne fired right up and sounded fine, the reduced performance message was still there so I drove ti easily up the driveway and back and the message went away.
It seems absolutely fine now, I guess I just really should nopt let it get that low, the estimated miles till empty is off I'd say by about 60 miles then. Anybody else had a similar experience.
__________________
Old 08-26-2007, 12:02 PM
2001 Volvo S60
Man, what are you doing letting the gas get that low? Just kidding.
IMO its the car preventing damage to the fuel pump by running it dry. The car will probably stay running until you go dry if its already on, but if the gas is very low (I think) the relay keeps the car from starting.
Personally I don't like to let the car get that low. Not because I am afraid of damage, but because I dont want to get stuck filling up when gas prices spike. If you're on E then you don't have a choice but if you have a half tank or so you can usually wait it out.
__________________
S60 2.4
Akebono, Brembo, Bilstein, OBX, Volan, Kuhmo, K&N, ipd
Don't enjoy my personal brand of humor? click here - if it doesn't work, click harder.
Old 08-26-2007, 04:04 PM
Thishas happen to my wifetwice now aswell.She no longer turns the car off if there is less than 90 mileson the tank withoutputting gas init. I thinkthe real reason is Volvo over reaching theircommitment to safety. Volvo thinks that it is safer not drive the car at all, then to run out of gas on the freeway at 80 miles per hour. Therefore they will prevent you fromstarting a car with less than a certain minimum amount ofgasoline in the tank.
Old 08-26-2007, 08:04 PM
Im not sure what year your s60 is but here is a tnn I found which may apply to your vehicle and may help you out .
MODEL/YEAR: S60, S80, V70, V70 XC, MY 1999-2002
SUBJECT: Crank No Start, No Fuel Pressure
A crank no start condition with the fuel level below one-quarter tank could be caused by a
faulty over flow valve in the fuel pump assembly. Whenever the vehicle is parked at an
angle, such as facing downhill, the fuel in the tank will settle away from the pump pick up.
The fuel pump assembly incorporates a reservoir that supplies the initial quantity of fuel to the
pump to start and run the engine. The overflow valve may allow the reservoir to drain down
below the level of the fuel pump pick up resulting in a no start condition. This drain down
takes several hours, typically overnight. Adding fuel to the tank will fill the reservoir, allowing
the car to start.
__________________
b5254t
Old 08-27-2007, 09:41 AM
very nice info B5254t. I think that solves that one. i kinda figured it to be thta kind of issue.
Old 09-22-2007, 12:11 AM
I had a problem like that, and the Volvo dealer said it was some kind of computer and they replaced for free because I got the extended warranty.
Old 10-10-2011, 08:20 AM
Sorry for the resurrection but I just wanted to say thanks for this thread - managed to get my '02 V70 2.0T re-started following this advice. I'd decided it couldn't be down to fuel level as I'd parked it with less than 60 miles left on loads of previous occasions. Also, the dash flashed up a few messages like "immobiliser see handbook" and "reduced engine performance" so I was beginning to resign myself to coughing up for repairs. Once I read this, the fact that the car had been facing downhill for 2 days gave me a bit of hope and now it's up and running again.
Old 07-25-2013, 11:12 AM
Default Start prevented message
My XC90 gave me this message the other day and it hasn't appeared since. I think I was running low on fuel. I took my car on a 80 mile trip that day. When I left on my trip the car said I had 120 miles to an empty tank so I figured I was good till I got back into town to fill the tank. I figured I had enough fuel when I got back because it said 60 miles to an empty tank but usually after a freeway/hwy ride, the fuel meter doesn't register the tank level well. I came into town and parked it to make a stop and the start prevented message came on. I waited a few minutes to try again. After three tries it finally started and I made it to the gas stations. It hasn't happened since. I'm also wondering if it might have something to do with the battery going bad on my key. There was another another post that mentioned this could also be an issue as well.
Old 08-15-2013, 06:19 AM
could any of these problems be down to the in tank fuel pump i have been having the same issues car not starting showing 70 miles in tank put diesel in car stars runs fine have been told faulty in tank pump ??
Tags
24t, car, engine, fuel, low, message, performance, pickup, prevented, reduced, running, s60, start, volvo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
