How to remove the A Pillar trim to hide a dashcam wire?
I have a 2015.5 S60 and I want to run the power cable for a dashcam behind the A pillar trim. I saw references to removing a bolt that is behind the airbag badge. Is that all I need to remove and replace the trim? Anything that has the words "airbag" on it make me very cautious.
Yes, I have done that many times for a radar detector - tuck the wire under the edge of the headliner, at the top of the a pillar cover tuck it under the edge for the 2 inches the cover is wide, then down the side of the a pillar cover under the rubber weatherstripping around the door opening. Take the cap off the end of the dash - then down to the Obd port.
