Still Missfiring after new coils 2.5T 04
Old 08-25-2014, 11:22 AM
gmcompu's Avatar
Default Still Missfiring after new coils 2.5T 04
On my 04 with 120K miles on it, i have a missfire on cyl #4 and sometimes on cyl #3.
I buy the car with this problem, i changed all the coils and the sparks, all originals from volvo.
But the problem persits on this cylinder #4.
The cars needs 2 seconds to start.
After the car starts, if i clear the codes i can ran 500 miles without the code apearing again.
The problem just appears when i start the car, after that the car runs fine.
Also the battery is new.
Could it be a leaking injector? I don't think of a compression problem, cause the car once started runs like a champ.
Any ideas???
Thank you!
Old 08-25-2014, 07:22 PM
damien360's Avatar
Other issues that can cause a misfire would be faulty injectors, spark plugs, bad compression, bad head gasket etc.
Old 08-28-2014, 01:22 PM
gmcompu's Avatar
In case it's a bad compression problem, don't you think that the car will lack power?
Arter the car starts the car runs pretty fine.
Old 08-28-2014, 03:15 PM
oragex's Avatar
I firstly don't think coils would cause misfire only when starting the car. So probably the coils weren't bad.
Given it happens only at start up, I would also go first with a bad head gasket - watch the antifreeze level when cold, over a period of time. Also I would check if the fuel pressure is right when starting the car - to see if the fuel pump works fine.
nmikmik
04-02-2015 12:37 AM
andrei3333
09-18-2009 03:51 PM
counterspyder
05-29-2008 10:02 PM
uniquemicro
03-04-2008 12:18 PM
Quick Reply: Still Missfiring after new coils 2.5T 04
