Issues with the automatic window regulator
On my wife's 2008 S60, the automatic window is Not working properly, when the window goes up it doesn't stay closed, it reopens the window unless you hold the button on the up position..
I tried holding the button on the up position as suggested but unfortunately didn't work.. any suggestions?
Thanks in advance!
Thanks in advance!
Thank you for the tip, the 'remove the fuse while the window is going down' trick did it, now the automatic window switch works as designed, which I am very glad as a new (OEM) switch cost is over $450.. Thanks again!
