Sponsored by:
Sponsored by: DashLynx
2001 S60 - Trunk Will Not Open with Remote
Old 05-30-2009, 09:36 PM
mjl's Avatar
mjl
mjl is offline
Default 2001 S60 - Trunk Will Not Open with Remote
My remote will not open the trunk any longer. Key works fine. Any ideas?
Old 05-31-2009, 11:46 AM
vegasjetskier's Avatar
You didn't push the trunk lock button on the center console, did you (or maybe the carwash guy did)?
Old 06-01-2009, 07:40 AM
adub96's Avatar
also there is a relay in front of the drivers rear tail light that if it goes bad the trunk lock doesn't pop.
Old 06-01-2009, 03:16 PM
thompson07's Avatar
I lost the nut for one of the thin wires connecting to the positive terminal on my battery and it caused my trunk not to work unless i used the key hole. Also caused the gas gauge to display nothing (empty) sometimes. New nut tightened everything down and problem was fixed.
Old 06-02-2009, 09:37 AM
razak-ms's Avatar
you must press the trunk release button on your remote twice slowly.
Old 06-15-2009, 05:04 PM
v60owner's Avatar
exact same problem just occurred on my '01 S60 - the garage replaced the fuse in the box inside the trunk, but that was not the problem. There is a "harness" that communicates the signal to open; the wires stretch and then snap over time. Once broken the signal cannot pass and the remote no longer opens the trunk. The harness is also on the left side of the trunk; it passes into the lid near the hinge.
kasey0505
08-18-2015 03:32 PM
RobertMoon
04-22-2011 06:28 PM
Vincef
03-18-2009 08:42 PM
Quick Reply: 2001 S60 - Trunk Will Not Open with Remote
