Sponsored by:
Sponsored by: DashLynx
Clutch Pedal question
Old 10-03-2011, 09:17 PM
KenE's Avatar
Default Clutch Pedal question
HELP! I'm having a clutch issue with my 2003 S60. The pedal basically just flops, there's virtually no resistance. It feels like the pedal isn't connected to anything, but when I look under the dash it does move master cylinder rod. The fluid reservoir is full and I don't see any sign of leakage out of the tranny. Is it my clutch master cylinder? I'd think there would be some slight resistance if the slave cylinder blew out and shouldn't that also pump out the fluid? The clutch is always engaged. My thought was to loosen the bleeder and see if anything will pump out, if it's the master cylinder nothing should pump out, if it's the slave then something should pump out - or am I looking at it wrong?
emptyc311
10-06-2010 09:53 PM
fastlate
11-12-2008 12:40 AM
muitas_tretas
02-21-2008 05:10 AM
rojones82
09-26-2007 02:46 PM
shaver5000
06-21-2006 01:54 AM
Quick Reply: Clutch Pedal question
