2002 Volvo S60 2.4 Timing belt question - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 08-02-2009, 08:04 PM
Default 2002 Volvo S60 2.4 Timing belt question
Hi, Im trying to change the timing belt on my moms S60. I printed out the Vadis manual for replacing timing belt. I can not get the top two gears (i guess those are camshafts) to line up with markings on the top plastic cover. I propably did 5 miles worth of rotations in attempt to achieve what is on the picture of the manual. Do I line up the "M" marks with the markings on the top cover?
Thank you
Old 08-02-2009, 08:11 PM
There should be little lines that match up with the cover. If not then like up the crank mark then make your own marks on the cam pulleys and remove the belt and install the new one.
Old 08-02-2009, 08:15 PM
Great, thank you! One more question, the lines are very small right?
Old 08-02-2009, 08:20 PM
Yes they are.
Old 08-02-2009, 08:31 PM
Thank you so much!
Old 08-02-2009, 08:41 PM
Your welcome anytime.
Old 08-03-2009, 12:26 AM
Damn, i havnt hear " VADIS" in like 3 years.
Thread Thread Starter Forum Replies Last Post
2002 Volvo V40 Timing belt question andoras1977 New Members Area 2 02-05-2014 03:50 AM
Can the Camshaft be turned CCW on 2002 s60 if timing belt is off DeanH Volvo S60 & V60 3 06-26-2012 01:43 AM
volvo s60 timing belt question Reid General Volvo Chat 3 05-27-2010 04:50 AM
2002 S60 Timing Belt Jakeman Volvo S60 & V60 0 03-04-2010 06:46 PM
S60, 2.4, 2002, Timing Belt Jumped/Slipped? jjack529 Volvo S60 & V60 19 12-15-2009 01:21 PM
Tags
2001, 2002, 24, belt, belts, change, changing, manual, replace, replacement, replacing, s60, timing, vadis, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
