2003 Volvo S60 2.4T Fan Will Not Stop Running
Old 07-02-2015, 12:10 AM
dadlovsyall's Avatar
Default 2003 Volvo S60 2.4T Fan Will Not Stop Running
I am wondering if low freon would cause the fan to run without shutting down even with the key off? I believe I read somewhere that low coolant would cause this. I don't have a clue. This is my 1st Volvo. Any suggestions would be greatly appreciated. Thanks
Old 07-03-2015, 08:38 PM
pkrface's Avatar
Volvo exclusive (to my knowledge) feature called afterblow. The fan will run on a cycle to dry out the A/C evaporator to avoid a mold issue. A quick google search or a search of the forum will confirm this for you.
Old 07-03-2015, 09:12 PM
Default Thank you pkr
I want to thank you for your input. It just seems to me the fan would eventually shut off. I realized the problem shopping one day. I left it alone overnight and it was still running the next morning. I had an appointment at the VA the next day and it continued to run. I finally unplugged it. Thanks again.
Old 07-04-2015, 09:11 AM
pkrface's Avatar
Aaahhh. Didn't understand the length of time involved. Many first time Volvo owners mistake the afterblow feature for a fan issue. In your case I would suspect a stuck relay or the sensor that determines when the afterblow kicks in being faulty. I have no personal experience trouble shooting this, but just based on my basic knowledge of electrical systems.
Old 07-04-2015, 12:52 PM
Default Thank Again pkrface
Thanks again for your help pkrface. I really appreciate your help. Have a great 4th of July weekend.
Old 07-04-2015, 10:36 PM
damien360's Avatar
What fan are you talking about. The fan in the engine compartment or the blower motor?
Old 07-04-2015, 10:41 PM
The engine cooling fan behind the radiator. Thanks for your help.. I appreciate you taking the time to look at my post.
Old 10-02-2015, 10:56 AM
Replaced Cooling Fan Assembly. I could not just replace the module. Problem solved.
nitch67
05-16-2015 11:16 AM
amadeo_244
11-03-2012 05:55 PM
gclin
03-23-2012 12:45 PM
pnhons
11-20-2011 05:26 PM
leonardd
08-06-2011 06:48 PM
Quick Reply: 2003 Volvo S60 2.4T Fan Will Not Stop Running
